Moving Newspro to a new drive
jjoslin
Post by jjoslin »
Just had to move my newspro dir to another drive. Looks like another maxtor is about to go belly-up.
I changed all of the registry entries that mentioned "D:\Newspro\" to be "N:\Newspro\" and started the program back up. It can't seem to find the database now. Any suggestions? I've done this in the past and never had a problem.
Regards,
Jim
you need to invoke file menu->switch database, point it to the superdirectory of the newspro database 'Data' directory.
e.g.
N:
NewsPro
Data
you point it to NewsPro
jjoslin
Post by jjoslin »
I appreciate the quick response, but, well, that didn't work. It still doesn't see the database itself. I had the files in a subdirectory called News under N:\Newspro... i.e.; N:\Newspro\News, so I chose that directory. The program does not load any of the files there at all. Any more ideas?
Pegleg
Jim does newspro ask you if you want to create a new databas
Post by Pegleg »
Hi Jim
Why did you change the registery entries ?
Have you move the newspro program itself ?
I switch database(s) often using the switch data command without problems. (but I've never tried moving the program :( )
If your using XP why not try changing the N drive to D as a quick tempory test, see if you find the datase on D (If so then you coulda missed a registry entry)
Good Luck
Pegleg
jjoslin
nope, no new database
Post by jjoslin »
Well, the registry change seemed to make sense. I had to move everything to a new drive. I'll try the drive letter thing, maybe that'll do it.
