move multiple groups to a folder
longneck
Post by longneck »
Is there a way to move multiple groups into a folder? Or subscribe (multiple) groups into a folder? I like to add 30+ groups at a time, then move them to a folder.
- Carl
just select the newsgroups and drag them to the folder with the mouse.
longneck
Post by longneck »
ah-ha! i figured it out. after you use shift to select a few, you have to make sure to not drag the group by the item that has the focus. if you do, then the whole group is deselected, and only the item with focus is moved.
- Carl
now i see, when you click the focused item it clears selection, just noone noticed that before.
i added some unrelated option in the development section, so i fixed this too:
http://209.15.161.125/newspro/phpBB2/vi ... .php?t=139
