Deleting Headers
stevendm
Deleting Headers
Post by stevendm »
After I download a message I have UE set to delete the bodies. I am not sure if I want to delete the header. Does UE work like NP and headers are not really deleted, just marked like they have been deleted. In NP I could always show deleted headers in case I needed to dl a message again.
Does UE work the same way?
Steven
ue works in the same way, but deleted headers can be displayed very fast by checking the 'del' check box in the quick filter, in newspro it is much more slower. if you check both 'del' and '^del' (it is also default after you restart the program when you click the leftmost checkbox in the quick filter) you'll see all headers - both deleted and not deleted.
then you undelete desired headers (from the context menu) or e.g. ctrl+a - to select all and then undelete (it will be undelete all then).
