Create XPAT search group from selected groups/folders?
butterball
Post by butterball »
Would it bepossible to have Newspro automatically create an XPAT search group from the selected groups/folders? On the right-click menue in the Newsgroup pane maybe?
Sometimes I like doing XPATs on the groups in my subfolders to get files that are not shown anymore due to my retention settings. This would be VERY helpful.
you just select the groups and invoke 'copy newsgroup names' from the context menu.
then paste the names into the newsgroups field of the xpat dialog in a search group.
butterball
alex wrote:you just select the groups and invoke 'copy newsgroup names' from the context menu.
I know. Just wanted things a little easier. I´m a lazy sob...
