My downloads???
ratedr
My downloads???
Post by ratedr »
ok Im a newbie I know. But I spent a few hrs downloading a few hundred megs of stuff..and now I cant find it all I see in the folder I tolsd it to download to...is 1000's of npr files? is there something I need to do with these npr files to get the actual REAL files I want?
Check newsgroups, if you see the messages have been downloaded (green and blue notepad icons) select them and invoke 'save attachments'
If you invoke download&save and there was no problem it will save after completing downloading within the delay defined in properties->general, autosave per seconds (left bottom corner), you may reduce the default delay if you like.
.npr files contain article sources but they are internal data files that are handled by newspro and one doesn't need to do anything about them.
