Maybe wiat a bit longer if the server(s) report the header is not available.
NZB handling
NZB handling
It appears that maybe UE is having a problem handling NZB list when some/or most of the post is not YET on the server(s). It tends to work it's self to death looking for things that aren't there YET. and then, etc etc etc
I always make the NZB's myself with NZB4U.
But then again, that's just one of the reason's I'm not in favour of posting NZB's of stuff that has not been posted yet.
To many things that can go wrong.
sideshowtob
NZB with missing bodies
Alex
Is there an option that can retry articled downloads after a certain period? This would allow me to import an NZB and then have UE keep trying to find missing articles as they are posted.
Re: NZB with missing bodies
Properties > Tasks > Retry failed article tasks every (x) min.sideshowtob wrote:Alex
But I don't know if it works for NZB downloads.
Rodent
sideshowtob
Already tried it and it had no effect. I set it for one minute and watched my articles. Nothing happened. I then did a manual retry on the queued articles and they downloaded the new bodies.
Thanks for the reply.
Rodent wrote:Properties > Tasks > Retry failed article tasks every (x) min.sideshowtob wrote:Alex
Rodent
sideshowtob
try to uncheck "delete incomplete bodies" in properties->articles so if an article body has been downloaded and the rest is still missing on the server it won't delete bodies after save so there will be no more task.
for "retry" to work you need the article landed in the "errors" pane, if bodies are deleted after save the task is removed.
This one worked fine (as expected), I guess I'll have to investigate what
is causing the failure of UE to realize it is already set up and doesn't require
me to tell it where the database is located each time..........
Drop this item. I'll find a way to work around whatever is causing my own problems......
Hal
Hal
