Import and export Servers
jonib
Post by jonib »
Hi
Is there anyway to export and import servers in Usenet Explorer?
This was one of the best things I liked about NewsPro I don't care if its compatible with NewsPro as long as it's some kind of textformat.
i could add it to the version for registered users (at least), remind me when i'll be back to ue code.
but why it is needed at all? with reg.dat backup you can save/move all settings including servers.
jonib
Post by jonib »
alex wrote:but why it is needed at all? with reg.dat backup you can save/move all settings including servers.
If I find a list of free news servers I would have to input them one by one not fun, just to test if they work.
If I could import then I could just make a list and import.
mariela06
Post by mariela06 »
alex wrote:i could add it to the version for registered users (at least), remind me when i'll be back to ue code.
Was this added anywhere at all?
I was changing one of my servers and changed the password. I wanted to copy the password from the other server, since they are the same, but can not do it, and since I can not export it, I don't know what it is.
You can get software (lots of freeware) that can get your password back. I imagine it should work in UE. Try a simple Google search here
