Manually rebuild parts
The Cat
Post by The Cat »
In newspro you could manually rebuild the parts you downloaded. Specially handy with two incomplete posts. I searched everywhere but can not find the function in UE. I must be 8) or has this option been lost in UE?
now with par2 recovery doing manual reassembly is much less actual.
i cannot copy all newspro options into ue or the opposite even if i've developed both programs, just there is not enough time.
if newspro would be written in 64 bit environment it would be well possible i could just develop it as a single project even after the usenet volume exploded, but there was no 64 bit then so we have what we have.
The Cat
Post by The Cat »
thx, now I don't have to look further. I needed it because somebody did a post and a repost and both are incomplete. But together I could fix it.
you can use newspro as well, export headers, import them into newspro and assemble them there.
