Where is the ban filter???
da_spook_uk
Post by da_spook_uk »
I am using news pro but this is not working for me anymore as it constantly crashes.
so I am trying newsnet explorer, the filter i used to use is greyed out
I need the ban filter
is there a reason for this???
newspro is quite reliable unless you try to download more headers than it can handle thus running out of virtual memory (about 4.5M per instance. but maybe some slowdown on header tasks for large groups as well).
in usenet explorer there are quick filter and usual filters (edit menu->filter editor). also check properties->newsgroups, you can (after creating it in filter editor) e.g. to assign a ban filter for all newsgroups as inial filter.
but better read help notes - UE.txt, it is all described there.
