bassie wrote:I deinstalled sygate and try zonealarm 6 suite. I was no fan of zonealarm in the past, because some updates could totally mess up my internet experience. Like certain files disappeared after download, no internet at all was possible, for example.
ZoneAlarm does have an annoying habit whereby it stops certain email attachments/downloads from saving properly. That's not a bad thing but I think it's a bit too protective. Go to ZoneAlarm's Email Protection tab and disable Inbound and Outbound protection. As long as you have decent antivirus and you check regularly with antispyware then you will be fine.
To make sure you haven't disabled too much, go to grc.com, specifically
Shields Up and run the tests there to make sure you're safe. The best way, though, is to have a hardware firewall and use ZoneAlarm to stop programs from calling home. This has the benefit of not tying up resources on a software firewall and it's a further layer of protection (hardware firewall->software firewall = two layers to get through). On my setup, my router has blocked every single attempt to connect to my machine - there are no entries in ZoneAlarm's log.
If you find ZA seems to have stopped your connection dead, make sure you haven't accidentally engaged Internet Lock. The keys for this are CTRL+L but you can right-click the icon in the taskbar to change it from locked->unlocked and vice versa.
bassie wrote:i will give this suite a change (without the antivirus part because i already have antivirus program). But i must say zonealarm also gives anouncements i cannot understand. Like: " should i allow CLI.exe to connect?" or something like that. Well, like in the sygate case i don't know, i would say:" zonealarm you are the expert on this, give me advice."
I don't know what this program is, nor some others....
I'm guessing you have an ATI card in your system. Check
here for more information. If you're unsure of what a file is, just put the filename into Google and it should come up with any number of sites telling you what it is. I bet a lot of people have blocked their Norton antivirus as well - the component that checks emails is called ccapp.exe, hardly a descriptive name. The newer ZoneAlarms call up the ZA database to check on particular files and give a recommendation as to whether or not you should allow or disallow them. You should see a traffic light with a green or red light to help guide you (unless ZA can't connect to the database). In the end, though, the choice is left to you on what action you'd like to take.
