UE 1.30 and Win98SE
laren76
UE 1.30 and Win98SE
Post by laren76 »
I have no problem with UE 1.28 and previous version. But I have the same problem with UE 1.29 and 1.30. I installed them, then I clicked it to start the program. The error message just said the program is crashed and asked me to reinstall. I did reinstall it, but it's the same error message again. That is to say I am not able to start the program! So I guess I'll stick to 1.28 version at this moment. Anyone else has the same problem like mine?
I am using windows 98SE.
i know what it is. it is a system limitation.
it is the new drop box to download limited par2 volumes in toolbar, i remember there was the same issue when i added the pause button, win98 has some limitation and won't load an executable if resource number is more than 32K, so i need to change the number to make it work on Win95/98/Me
why you didn't report it yesterday?
ok i'll replace the resource ID and recompile it.
try to download the file again it should work now.
i didn't change the version number, just the UeExtractor date is now April 14.
laren76
Post by laren76 »
Thanks! It works!!! :)
