How to reduce size of "Bodies" folder?
Saugruessel
Post by Saugruessel »
the Bodies folder under uedata on my PC has grown to 8 GB. How to reduce its size?
Regards
Saugruessel
edit menu->bodies when delete them all if you like, the size should drop drastically, then if you restart the program it will drop a little further.
these are just non-deleted bodies in newsgroups, you can change settings in properties->articles->save queue (press question sign button for short help) so it deletes everything clean, just it may give some options to the user in case of download errors.
