[REQ] Filecheck -- check if file(s) have been dl-ed before
wolverine2710
Post by wolverine2710 »
Bought license few months ago. Switched recently from BNR2 to newspro. Finally gave up on instability of this otherwise excellent prog. Miss several nice features of it but one feature I really miss is 'filecheck'. Program remembers (using cvs files) which files where downloaded and from which newsgroups. Extremely usefull for picture/mp3 files, trust me..... When I try to dl something which is in a csv file the prog warns me. Nice. Afaik newspro doesn't have this feature. Are there any plans for such a feature. Would make life much easier...
/Wolverine.
I'll check such issues some time later, I need to finish something here first, then the time will come for the rest, maybe in a few months.
wolverine2710
Thanks for the response. Good to know that it is something you probably will incorporate in the future. Can't wait ;-)
g00fy
Post by g00fy »
I asked about this twice in the support section, but that was removed everytime. Now I read this post. Can you tell if this feature will be implemented, o, if it already has, how do I set it up?
tijgert
Post by tijgert »
Also; let some record be kept of files in the que that were leeched (and saved) before windows screetched to a halt.
That way, after a database rebuilt, it won't start leeching files that you had hours ago and waste bandwidth.
