Post efforts
Contrabanda3365
Post efforts
Post by Contrabanda3365 »
Alex,
Could you support me please. What's the best way to post binaries? UE or other applications?
I'm reading several topics on the Internet and it confuses me.
I would appreciate your help.
By the way I purchased your UE.
Contrabanda3365
UE has several advantages over power post, you can resume posts in several sessions even if connection failed or retry post if there were errors or even redirect the rest of posts to a different server in the case of an error. It also can remember you previous posts so you can use them as a template to make future posts.
there are similar posting capabilities in newspro http://www.netwu.com/newspro/posting.htm
the difference is in adding par2 and nzb capabilities.
as to par2 to enable par2 just press "Start par2" after the process has been finished the "par2" check box will become enabled.
as to nzb if you checked it and started posting - never cancel the post, since it is not possible to generate nzb from several posting attempts, if there are errors just invoke "retry" - from the post dialog or the from post and post error panes in the task manager.
i'm planning to add newspro like topic describing posting in more details.
if something is not clear just ask and i'll try to explain it here as well.
