only 1 par downloaded&saved
augurk
Post by augurk »
Since a month or so i have this problem: when i do a search, select the files and do a 'Download&save attachments (auto)' (and i do this about 99.9% of any downloads with UE), there is only 1 par file, usually the fourth, that is selected for dl&s in the collection in the import tab. I have searched for an option the may cause it but haven't found any...Any solution? Thanks.
there are options in the toolbar (they are also listed in the tasks menu), in short uncheck "tasks menu->mark limited volume of par2 files for download".
hholland
Post by hholland »
Percentage of post in pars or number of pars might be better than using Megs of PAR. (In my opinion). I know that computing percentage would be difficult and a hassle tho. Maybe just number of par headers ...... I dunno....
I haven't fine tuned the Megs of PAR's yet. Kinda depends on size of the post :)
