Sticky settings (per group)
kheldar01
Post by kheldar01 »
Hi
just a little question / request,
I set on default newsgroup properties to use collections and then for the various group subscribed yes or no on using collections depending on group, but i'd like to set show files / hide files in collections on group basis, but when I click the button on the toolbar the choice is not recorded, so on next run of UE I have to set that again. Is possible to sticky a custom view for each group and save that?
no hide files doesn't make much sense at all since initially collections are shown as collapsed so the difference is only in the + expand sign, just if you expand a collection it will remember the expanded state during the session so by show files/hide files you can collapse all collections temporarily.
