Show attachments inline
tommyd
Post by tommyd »
How can I change the default file extensions shown inline?
the syntax is boolean wildmats, the same as described here http://www.netwu.com/ue/help/patterns.htm
so if e.g. you want to leave only nfo and txt extensions you can use
*.nfo|*.txt
or even
.nfo|.txt
since the asterisk is not actually needed
in short you can put in properties->articles->show attachments inline anything within the revised in v1.7 boolean wildmat syntax
| in boolean wildmats means OR (so you cannot use something like "*.nfo, *.txt" or "*.nfo *.txt" because it won't give any matches)
