Moving setttings from one database to the other
hq3
Post by hq3 »
I'm using News Pro with the multiple database options,
I found that I have to manually set NP options with each new database created.
Is there a way to copy the settings from 1 NP to the other?
HQ3
(the other problem I had, resloved it self when I switched to multiple databases)
most settings are in reg.dat, you need just to copy it from another database and then run file menu->reset database in the new database.
it is also described here:
http://www.netwu.com/newspro/phpBB2/viewtopic.php?t=9
