export full newsgroup list, not only suscribed, possible?
folgui
Post by folgui »
Hi!
I would like to export que full newsgroup list to a text file. Suscribed newsgroups (1st tab) or servers have this option, but not que full list (3rd tab).
I've also looked for it in the NewsPro database directory, but file Newsgroups List is not "visible" ;)
Some way? or otherwise an url where a can get that list (most well known groups)
Thanks in advance.
Regards, folgui, a NewsPro lover from Spain.
jsdkr
Post by jsdkr »
ola
If you open file\ newsgroup list or the third tab, then right click on the newsgroup list window pane , one of the selections is all newsgroups \ copy all . Then just paste to a text file . :D
==================== :mrgreen: ==================
folgui
Post by folgui »
Argggggggg!!!!!
Didn't see it, I was looking for "export" XD
Thanks ;)
A few hours later...
But the copy and paste doesn't work ok, the paste mixes all newsgroups, several groups per line, not one per line :(
Two much job to put them like they appear in newspro.
