create a filter
telex
create a filter
Post by telex »
how can I create a filter that files that are smaller than 50kbyte are not shown? I habe problems to use "<" and ">" inside fílter.
and how do I do the "reset and extract" or "reset and ban" function like it was in newspro?
try to check the filters topic on the ue web page http://www.netwu.com/ue/help/filters.htm
mariela06
Post by mariela06 »
alex wrote:try to check the filters topic on the ue web page http://www.netwu.com/ue/help/filters.htm
How do I combine two (watch) filters to work like the quick filter toolbar?
For instance, how do I create a filter that has
Subject contains ABX and also author begins with ABC@
I read the filter information but was not able to figured it out. Every time I insert the filter, it is a new one, does not append to the previous. If I leave the name blank, it gives me an error without appending to previous filter's predicate.
jonib
Post by jonib »
mariela06 wrote:Subject contains ABX and also author begins with ABC@
You need to make a Subject filter and a author filter and then combine them with a composite filter, check the help for composite filter to learn more.
jonib
