Move from one message to another ?
plasmannc
Post by plasmannc »
If I have several messages with bodies is there a way to move from one to another without having to go back to message (header) list?
At present what I do is dl a number of bodies, select a message, click it to read, close the window after reading, select new message, etc.
In the old Forte agent reader you could go from one message with a body to another by just pressing a single key that took you to "read next message with a body"
you can check "bodies" in the quick filter (if you have collections enabled also press (thread menu or toolbar button) "show only files matching filter in collections", then you see only bodies, then you can split the view and move up and down with up/down arrow keys using mouse wheel to scroll the article view while mouse cursor is in the article view area without setting focus to it.
plasmannc
Post by plasmannc »
Thanks Alex. Knew there was a simple solution considering the outstanding quality of UE.
just noticed in file menu, navigation, there are shortcuts next body and previous body, it also keeps the focus in the article view, so it is exactly what you want, i think someone asked in the past so i added it or i took shortcuts based on newspro at a very early development stage.
