ImportingNZB From Article List?
stevendm
Post by stevendm »
I am viewing articles in a newsgroup. Is there any way to select an article that contains a nzb file, right click, and download all of the individual articles pointed to by the nzb file?
The only way I know to do it now is to download the nzb file and then go to the import menu selection and download the articles.
you can download&save it into the import folder.
stevendm
Post by stevendm »
That seems to only download the nzb file. I was hoping for something that also started downloading all of the articles at the same time.
edit menu->properties->general->import/search, associate nzb files with action you need to change the action from "import only" to "import&download&save".
"import&download&save" is now the default setting for new installs in v1.9.5, i also added the words "including import folder" to make the setting more clear.
you've made a good point, just in first UE releases when the group default save directory (properties->newsgroups) has not been defined - the general default (the topmost "default" entry) was variable reflecting the last user choice when invoking "download&save", then i made the entry fixed (still remembering the last user selection but keeping it separatedly) so properties->newsgroups would always giving an invariable destination - set by the user in properties or when not set being the "downloads" directory in the ue database directory, i.e. always easily predictable - at that point the setting could be changed this way.
