Download and save later
plasmannc
Post by plasmannc »
Should know this but I don't.
How do I do a download and save later? As soon as I select files and choose dl&s later the download begins. I want to be able to select a varity of different articles, check nfo's and then begin the download at a later time.
I know it is something simple but I need help.... :(
in the tasks menu you need to check "suspend article tasks marked for later download" or something like that, so you toggle it to mark for later download.
you can also keep the option checked and just drag the articles above the download later priority range, if it is exactly above (to put in the tail of the rest of the queue) you should drag until you see upward black arrow while dragging (as a drag cursor).
and in properties->articles, advanced, download later priority, you can set the range of priorities which will be used to mark for download later (the priority which is set there and lower).
plasmannc
Post by plasmannc »
Many thanks alex....
For my purpose I think using the suspend option on the task menu is best. WIth so many options in UE just missed it.
