Can´t download from import folder
BigJens
Post by BigJens »
Hi there,
just tried to download something from my import folder by double clicking - nothing happened :-/ What´s wrong here? Do i have options about this in the menue?
I am on 1.9.9.7 and just re-installed everthing from sratch ...
BigJens
ensure the server(s) are still attached to the import group (you can see the servers by clicking + to the right of the group name, no + means no servers).
if you see no servers, invoke context menu->advanced->attach all servers.
make sure your firewall/antivirus doesn't mess with at least UE settings directory. the problem cannot happen if you power off computer suddenly or kill UE process, should be some inteference to cause that.
or if you reinstalled all from scratch maybe you just forgot to add a server at all.
BigJens
Post by BigJens »
Attach servers to the import group ... okay okay i just started laughing about myself. Works fine of course!
J.
I thought UE gave a warning if no servers were attached. If it doesn't, maybe it should... :shock:
