request: some support for binhex
carlosg
Post by carlosg »
is possible to disable the "end of part -- ..." when you save as text or source a multipart message encoded in binhex (this 2 lines don't let decode the file with winzip) ?
I download somethings from macintosh groups and are encoded in that format.
thanks
a problem with binhex (or rather mac encodings) every program posts its own way. as to this specific post you can remove the line in editor (e.g. ultraedit allows you to look in many files). also there are other decoders, you may try them. there is a possibility i'll return to the binhex issue some time later, i have other development targets to meet first.
