Problem adding 'Recent Folders' button to toolbar
mrvegaz
Post by mrvegaz »
I can add the 'recent folders' button to the toolbar, but it won't let me add a button image to it. Also, when I click on it, the dropdown list doesn't show me my most recent folders like it does when I use it by right-clicking in the Unpack pane, but instead it tells me I'm a 'Dummy'. :?
I'm trying not to take it personal, but maybe UE is trying to tell me something?
no, the folder is created dynamically, if i don't add some dummy entry in the resource editor i cannot create pop-up menu in the resource editor, instead of pop-up menu it willl be just regular menu entry.
it adds entries when you press the right menu button in the unpack view.
i could try though to move the code into separate function and add the same as dropdown menu of the "open default save folder" and in the unpack menu, but i need to call custom code since the menu is created dynamically.
when it adds folders it deletes the dummy entry so you don't normally see it :)
frankly i had a thought to add it to the unpack menu as well, but then it just somehow was gone.
i made it customizable in the latest version, a bit weird way to add it, the standard handlers don't work with the GUI library as to menu bar/toolbar entries.
don't dare to open UE.exe in a binary editor, i don't take any responsibility for what you may find there in the random byte sequence :)
