My PARs R PARring Automatically - Why?
DooWop
Post by DooWop »
Recently the PARs went on auto and I prefer to run them myself. How/can I turn off the "auto" feature? TIA
edit menu->properties->save/unpack, you can uncheck "auto" for example. to deactivate all unpack completely uncheck "auto add" instead.
but maybe you better uncheck "clear/delete on success", so nothing will be deleted, but you let UE to repair, basically unpack pane when active saves bandiwdth and CPU - UE is less CPU intensive than quickpar for example and quickpar is the best as to CPU among other repair tools.
DooWop
Post by DooWop »
Thank's Alex - It worked great!
