search is expiered in 4 days
my UE shows the message that search is expiered in 4 days. Is this right? Do I have to re new it? How can I do this?
Re: UE is expiered in 4 days
Check this thread new licencse... but how ?telex wrote:my UE shows the message that it is expiered in 4 days. Is this right? Do I have to re new it? How can I do this?
jonib
xp-AntiSpy or XP-Antispyware? Hopefully you don't have the dangerous one.telex wrote:...XP-antispy...?
There's no easy way in XP to do the same as in Vista other than following the steps outlined here and here. These are awkward and time consuming and they might not even fix or narrow down the problem.
In the end it's up to you to decide whether or not you find the lack of one button on one page to be enough of a deal-breaker to try and fix this problem. Are all other sites fine? If so - and you've already reactivated UE - then why bother...?
Additionally, why not continue to use Firefox? It's much more customisable, stable, safer and if there's a problem it's easy to disable add-ons or uninstall/reinstall it.
Also, download CCleaner and run that, making sure Internet Explorer and Temporary Files are all selected. Making sure your cache is clear could allow the button to be generated in case your cache has corrupt files in it.
