Scroll
dracula
Scroll
Post by dracula »
When I'm browsing the search or the task manager and scroll to see the next files every time skip 3 files. So if i see the files rar01 till rar30, and i scroll 1 time the first file start at rar33. Is it possible to change this becourse now every time i must go manually back.
I already try to change my mouse settings but that doesn't work. Maybe it's a setting that i can't find? :lol:
right now it is page at a time or 3 lines at a time (or if page is less than 3 lines it will scroll less), no option to define how many lines at a time to scroll, although it could be easily added if to find more space for the option in the properties->general pane, for now it is constant 3.
e.g. ctrl+arrow up / down will scroll one line at a time.
dracula
Post by dracula »
Ok Alex i thought maybe it was a wrong setting on my side. :wink:
If i hold ctrl and scroll it's works ok. Than in the search i see first as example rar01 till rar30, and when i scroll one time it go further from rar30 till rar60. So my problem is solved.
Maybe you will answer my other question now I'm busy. :lol: Is it possible to set the download counter from MB to GB?
yes, if it keeps MB after it crosses 1024MB, need to change to GB, i'll change it in the next version.
dracula
Post by dracula »
Thanks now it stays MB. I have reset my counter, but now already it is: 29045.41 MB. :wink:
