Search Service Down?
Contact support if you cannot find something or experience any other problem with the search service.
Stoker
Post by Stoker »
Hello Alex,
I've been trying to use the search service for several hours now and I get the message box "Search Failed A connection attempt failed because the connected party did not properly respond after a period of time, or"
Any estimated up time? Thanks.
dengle
Post by dengle »
i had a tech out to the house to install new internet service. It's still running off of the old one which is working fine, but one of the servers is now offline. He may have bumped it or done something else stupid. I should be home in 2 or so hours and check out what's up with the server.
dengle
Post by dengle »
Stupid tech decided to use one of the servers for the new internet (even with HUGE signs saying DON'T TOUCH on it) so essentially it was disconnected. All fixed.
search service monitor is not currently running (since yesterday), so i couldn't detect it in time, in one week the monitoring will be resumed, until then i'll be checking it twice daily, probability of those events is small.
