I can`t save any folders
mascagni
Post by mascagni »
I can`t save any folders. When I start Newspro, all the previously created folders vanish and the groups are listed without being grouped into folders.
i think i know what is the problem, you unchecked properties->general, show folders, it defines the state on start, also you can show/hide folders from the context menu without affecting startup, although if to make the option persistent (the last state set in the context menu) it may be even more confusing, since once you hide folders - they won't appear on the next start and currently you should specifically go and uncheck the option that is not directly seen.
