How to relocate Import folder?
foxpro
Post by foxpro »
Is there a way (ini file) to change the location of the import folder?
I would want it on a different drive away from everything else.
Thx.
jonib
Re: How to relocate Import folder?
Post by jonib »
foxpro wrote:Is there a way (ini file) to change the location of the import folder?
I don't know any setting, sorry.
Thx.
If you are using NTFS you can make a junction point where you want that points to UEs import folder.
jonib
If a junction point is treated as directory, then it is possible to delete the UE import folder and then to create junction point with the same name pointing elsewhere?
foxpro
Post by foxpro »
jonib wrote:If you are using NTFS you can make a junction point where you want that points to UEs import folder.
jonib
Interesting concept. Never used it to be honest. Would prefer a more straight forward solution inside UE, though, to keep it simple.
jonib
Post by jonib »
alex wrote:If a junction point is treated as directory, then it is possible to delete the UE import folder and then to create junction point with the same name pointing elsewhere?
Yes.
jonib
jonib
Post by jonib »
foxpro wrote:Interesting concept. Never used it to be honest. Would prefer a more straight forward solution inside UE, though, to keep it simple.
Inside UE is up to Alex. With my idea you can have your import folder wherever right now 8) , and should be easy with for example Junction Link Magic.
jonib
