Download and Save Multiple Collections at Once
ShaggyDragon
Post by ShaggyDragon »
Hi All,
I'm not sure if I've missed a feature here, but is it possible to select multiple Auto Collections and download them into multiple auto named folders? Currently when I select multiple, it creates a single folder with the last selected collection subject name and puts all downloads in there.
Cheers.
if you select for download it rather takes the headers than collections, so the folder will be the same.
collections were added about a year later after the first release, but the database remained compatible you can even disable them completely which will take effect after restart, there are some code adjustments in some places when collections are enabled, but not here.
