Opening multiple nzb files at the same time
deadken2
Post by deadken2 »
Because of changes to Newzbin I've resorted to downloading individual NZB files and opening them manually in UE.
Unfortunately, UE is not handling selecting and opening multiple files at the same time (via OPEN in Windows Explorer).
I get multiple dialogs on where to download the files to, but only the first NZB file is handled properly. The others seem to be ignored.
You can use the import menu in UE, you can open multiple nzb files there and there will be only one dialog, but if you use the "auto" download&save option it will create separate directory per nzb file.
If there is such a problem with windows explorer as you are describing - to work correctly it should be the same way when opening from the import menu, I'll check it out, windows explorer launches the application multiple times, so (if possible) it should catch subsequent file names while the browse for directory dialog is open. There is "auto - folder out of nzb name" in properties->general, import/search so it won't ask for the directory at all.
