Sort order
MrEman
Sort order
Post by MrEman »
Not sure how this happened and I'm sure it's a simple fix
UE settings call for a sort on subject
But some of my subscribed groups sort on the subject BUT in reverse order?
(Z-A should be A-Z)
Checked all my settings just cant get a couple of them to sort the subject A-Z instead of Z-A
Any ideas?
if you press the subject column the sort order will change to the opposite.
it just remembers the last sort order.
