Happy with UE but a few questions
LittleMadini
Post by LittleMadini »
first of all i love this newsreader. It´s not very good looking at all but I feel like using a Pro-Newsreader,
it´s so much customable and the search service is outstanding.
Ten times better than other newsreasders i tried.
So i only have small questions:
1.) Is there a option to autodelete the nbz file and the sfv file ( and optionaly even the nfo file ) after auro-unrar ?
2.) Is there a way to prevent UE to switch to the Import folder after "Download and save" something from the search service in order to download other results instantly too ?
Thanks in advance
NoNo
Re: Happy with UE but a few questions
Post by NoNo »
Hi, new ue member :D
1 - unfortunately that option is not available
2 - just unckeck "Open import group" in F5->General (Import/search)
LittleMadini
NoNo wrote:Hi, new ue member :D
Thank you =)
as to auto deleting files of certain extensions there will be some solution in the next version
LittleMadini
alex wrote:as to auto deleting files of certain extensions there will be some solution in the next version
this would be very cool !
