Download speed unstable on latest version 3.0.2
joep
Post by joep »
Hello
My download speed is very unstable with this last version
Normally the speed is 9 MB , but now it runs between 2 and 7 MB
When I go back to version 3.0.1 the problem is gone
Is there a solution for this problem
Greetings and sorry for the bad English
joep
jonib
Re: Download speed unstable on latest version 3.0.2
Post by jonib »
Try to uncheck the new Bypass database storage in Menu->Properties->Save/UnPack
jonib
joep
Post by joep »
No that doesn’t solve the problem
Thanks anyway
Joep
There is different system cache behaviour in Win7 comparing to WinXP. This file resolves it.
http://www.usenetexplorer.com/ue3021.rar
But it also includes some other changes things which most likely work, but I'm still testing.
There is also small 3%-5% drop bypass versus no bypass (9.0MB/s / 9.3MB/s) because of hard drive speed maybe in conjunction with system caching bottleneck (I have now only data on Win7 on 80mpbs connections, in WinXP only 50kbps).
I had original idea a bit stronger than the current implementation and I'll try it here if ok it will make into the next release, what I implemented by now is a simpler solution, in the stronger solution there is no such bottleneck at all, but maybe it only makes sense for faster connections (but anyway as time goes the connection speed doesn't get any slower).
I think with connection speed around 160mbps connection gets faster than hard drive, so either hard drives will get faster (e.g. higher RPM will be the standard) or raid should be used.
joep
Post by joep »
Hello Alex
Version 3.03 runs great
Speed very stable ,when bypass off it is 9.5 MB
When I put bypass on, it goose between it is 9.33-9.5 MB
Thanks for the very good support
Greetings
Joep
