Search error
yvonne
Search error
Post by yvonne »
Hello i have a problem with search
He give a message: search failed (cannot find server or DNS error)
How do i solve this problem
Greetings
Yvonne
Re: Search error
Please post search related questions in the search service forum section (I'll move it there after your reply).
Did the search work before and nothing in the system changed like antivirus or firewall settings?
If so maybe ISP problem with the route or DNS, if the problem persists we could troubleshoot it further (try to restart system/reset router first).
You may also try edit menu->properties->search/import, reset search configuration, but normally it doesn't change anything.
yvonne
Re: Search error
Post by yvonne »
thnx I will look at that,and let you konw if its works
