needs time before UE is starting
telex
Post by telex »
in the past months I have problem to get UE quick starting .
every time I enter UE the harddrives are running/scanning a while before UE is starting
Re: needs time before UE is starting
invoke edit menu->bodies.
delete all article bodies or those you don't need.
or, the same, you can delete the "Bodies" subdirectory in the UE database directory while UE is not running.
telex
Post by telex »
there are no bodies. It has something to do with my norton. When I switch on the extern harddrive it needs a lot time longer.
[edit) I installed Norton 360 new and it seems to be everyting okay now...
