Headers per server (range) all others" question
willko
Post by willko »
Hi all,
re: "Headers per server (range) / All others"
What exactly does the "retain/delete all others" setting do?
I have header retrieval set to All ATM & retain all others as default for all groups - if this was delete what would that effect?
many thanks
Re: Headers per server (range) all others" question
The option is applied mostly for retention, since article numbers are not held for all newsgroups storage types but one - the article numbers type.
If you choose "retain" - since older headers won't be deleted then - they will be accumulated until you delete them manually.
