Posts not arriving on server
lestertrad
Post by lestertrad »
I've tried to post only a few times, but each time I do (always a response to an existing post) my post never shows up on the server. I followed the tutorial on posting. What might I be doing wrong?
TIA
Les
Re: Posts not arriving on server
Check for errors tasks menu->task manager, if the rightmost error sign pane the question sign turns red and you see some errors there. If the question sign is grey then the pane is empty (then if you keep the post view the status field will be "Success"), it means the server accepted the post.
If no errors - contact your usenet provider and ask why your post didn't come through, they could disable or postpone posts even as their server accepts them.
