What files can I keep when upgrading to x64 version?
10minmon
Post by 10minmon »
Hi!
Is it possible to copy over the newsgroup, server, etc. config files when transferring from x86 to the x64 version of UE? What about the database files?
Thanks.
Re: What files can I keep when upgrading to x64 version?
database is compatible through 32 bit and 64 bit version, so one can use any version alternatively, you can also use the same database from different windows installations systems one at a time (not e.g. simultaneously from two different computers through network).
10minmon
Post by 10minmon »
Excellent. Thanks!
