Unraring
boston62
Unraring
Post by boston62 »
Alex
if there are no par files will UE attempt to extract the collection of rar files even though they are in the Unrar tab? I extracted them manually. Look at this screen shot. Thanks as always.
Re: Unraring
You can invoke unrar manually from the context menu or you can configure edit menu->properties->save/unpack to do unrar without par2 verification, but in the latter case it will try to unrar when rar is not complete.
boston62
Re: Unraring
Post by boston62 »
alex wrote:You can invoke unrar manually from the context menu or you can configure edit menu->properties->save/unpack to do unrar without par2 verification, but in the latter case it will try to unrar when rar is not complete.
Are you saying that it won't first check to see if a repair is needed, if needed it will run the repair, then do the Unrar? If I set it in the config to Unrar without the Par2 verification, it will attempt to unrar an incomplete Rar file?
semel666
Re: Unraring
Post by semel666 »
how is it possible to check whether repair is needed or not if there is no par2 files available at all?
boston62
Re: Unraring
Post by boston62 »
Thank you for replying. You are right. Great improvements in the last Betas, Thanks for the NFO part.
Re: Unraring
The releases are not betas, those are just improvements over earlier versions and the code is clean, it is usually the case, if something is reported I fix it right away.
boston62
Re: Unraring
Post by boston62 »
alex wrote:The releases are not betas, those are just improvements over earlier versions and the code is clean, it is usually the case, if something is reported I fix it right away.
That's great, again thank you for the reply.
