Workspace & Collections
boston62
Post by boston62 »
I downloaded headers, they are marked as new, but some of them will be Black colored, and the rest will be Red, or what ever color that is, but the Black ones have a Blue Dot in front of them, can anyone tell me why. Here is a screen shot, also if I just put a check the Yellow Box in front of a collection, does that just download the headers for that, but doesn't save the Attachments?. I could not find anything on this in the Manual.
Thanks for the help
jonib
Re: Workspace & Collections
Post by jonib »
It looks like the headers that are black aren't new anymore.
On my WinXP system I have flags where you have the blue dots, I assume it's the same. The flags indicate that the header wont be deleted automatically by UE (similar to a start in some programs), to toggle just click on the place of the flag or rightclick->Contextmenu->Mark.
If it's not the flag function, then I don't know.
If you check the yellow box UE will only download and not save, so you would need to save it manually later.
jonib
boston62
Post by boston62 »
jonib wrote:It looks like the headers that are black aren't new anymore.
jonib
Once again Thank you for the explanation.
NoNo
Post by NoNo »
IIRC the blue dot show results for the "find filter".
If your "Quick filter bar" ends up with the far right buttons "Apply" and "Clear", just hit "ctrl+f" then "esc" and blue dots should be gone.
Hit again "ctrl+f" to get the regular "Quick filter bar".
jonib
Post by jonib »
Jupp, It's the quick filter highlighting the files. Apparently I have never used that feature. :oops:
It's fun to learn something new. :D
jonib
