Newsgroup List
boston62
Newsgroup List
Post by boston62 »
I think I use to bring up the Newsgroup list and then right click and choose Subscribe, but now I don't see where to Subscribe to a group I want, has this changed or it's possible old age is setting in fast. Thanks
I just went and looked at the manual for UE and it' use to be there, now it's gone, was it moved?
jonib
Re: Newsgroup List
Post by jonib »
Double clicking the newsgroup seems to subscribe it.
jonib
boston62
Re: Newsgroup List
Post by boston62 »
jonib wrote:Double clicking the newsgroup seems to subscribe it.
jonib
Thanks you
I just did a clean install of UE, now I can't download faster 1.9 mb/s
My other program is working right so it's not the server, will keep at it.
Re: Newsgroup List
Newsgroup list menu was inadvertently affected, you can click Enter, mouse doubleclick or even create a shortcut until I recompile the code.
As to speed maybe you need to increase the number of tasks per server, with astraweb frequently the bandwidth per article task seems to be limited.
boston62
Re: Newsgroup List
Post by boston62 »
alex wrote:Newsgroup list menu was inadvertently affected, you can click Enter, mouse doubleclick or even create a shortcut until I recompile the code.
That fixed it, increased it to 10 it was set at 3. now over 3.3 mb/s. Thanks Alex
