Change Font in Article Window
jimmellish
Post by jimmellish »
Is it possible to chenge the font in the article window ? I can change the foreground/background/selected colours but not the font.
Re: Change Font in Article Window
font is the same as headers, currently there is no distinction.
jimmellish
Hi Alex,
Using the Font & Colors dialog I can change the other fonts, but not the font of the articles. BTW this is in Windows 7 64bit with Usenet Explorer v3.3 64 bit.
It may be revelent (and this was going to be my next post !), the article window does not always refresh correctly when the content changes. I get residue where the previous content does not clear completely and this appears as many dots.
Jim
jimmellish
I thought I would send a screen capture of the font problem. Here is what I found:
1) Start with Usenet Explorer maximised.
2) Change font. Article window does not change.
3) Restore window size. Article window now shows correct font.
or
1) Start with Usenet Explorer in un-maximised window.
3) Maximise window. Article window now shows correct font.
Maybe font change notification is not delivered, but i remember there is hadler, if there is handler i'll check maybe something related to windows 7 vs winxp.
