NZB parsing
lordstalker
NZB parsing
Post by lordstalker »
Stilling running 3.1.1. Would like to know before upgrading, does the lastest version support this type of XML parsing?
Code: Select all
<?xml version="1.0" encoding="iso-8859-1"?>
<!DOCTYPE nzb PUBLIC "-//newzBin//DTD NZB 1.0//EN" "http://www.newzbin.com/DTD/nzb/nzb-1.0.dtd">
<!-- NZB Generated by NZBsRUS.com -->
<nzb xmlns="http://www.newzbin.com/DTD/2003/nzb">
            <file poster="Comfun" date="1307748797" subject="Hen Zemi - 10 (720p|.mkv|h264|aac) ~bY WhyNot [01/18] - "[WhyNot]_Hen_Zemi_-_10_[74EEFD00].mkv.001" yEnc (1/39)"><groups><group>alt.binaries.multimedia.anime.highspeed</group></groups><segments><segment number="2" bytes="667793">1307748798.49781.2@eu.news.astraweb.com</segment><segment number="5" bytes="668386">1307748798.53487.5@eu.news.astraweb.com</segment>
3.1.1 can 't parse these correctly.
SpeckledJim
Re: NZB parsing
Post by SpeckledJim »
I've also noticed this problem with nzbsrus.com. Seems to be a recent change, as their nzbs used to import without issues.
Re: NZB parsing
i see it now, i'll check it out.
Re: NZB parsing
It appears they are trying to save website bandwidth.
Just redownload the current release, in help menu->about you'll see the version 3.3a, it handles those nzb files.
