Bodies Download question (3.4 x64)
rmark1
Post by rmark1 »
It's difficult to describe, but basically if I have more sections to download than the maximum bodies tasks, then each section only has one "running" download against it. However, if I have less the maximum bodies tasks to download each section has the maximum possible "running" downloads against it.
Is this the expected behaivour?
Ta,
Richard.
Re: Bodies Download question (3.4 x64)
Yes, it is expected behaviour, it just tries to minimize disk accesses.
There is the "optimize" check box in edit menu->properties->save/unpack, save, saving attachments, save, to the right of "bypass database storage". If you uncheck "optimize", UE will normally finish one attachment before moving to the next.
rmark1
Post by rmark1 »
Hi Alex,
OK, I understand now.
Thanks for your speedy reply.
Richard.
