Select attachments to post default folder
Carol
Post by Carol »
I click Add and the "Select attachments to post" window opens. Can I set it to open a default folder
instead of the last one used?
Thanks,
Carol
Re: Select attachments to post default folder
In principle it could be implemented that it will be the folder set in edit menu->properties->newsgroups, posted messages, "save folder" (even as there is no save folder for posted messages, it is why as to now it is not defined). I can add it in the next version or if there will be any correction of the current version, I'll reply here then.
Carol
Post by Carol »
Thanks for replying so quickly.
Carol
I've checked the code, it doesn't use the default folder.
It remembers the last folder used to post files and it opens that folder.
Carol
Post by Carol »
Thanks for letting me know it can't be changed.
I appreciate your effort.
Carol
Is any problem with the current arrangement, when the folder accessed the last time has been deleted?
Carol
Post by Carol »
No problems, just trying to simplify things.
Thanks again.
Carol
I'll change it so it won't forget the parent folder when a subfolder has been deleted, it is the only problem I've found (windows default behaviour), the function used rarely (import nzb files and post attachments), in all other cases the folder path is adjusted properly, it should be all ok then.
Carol
Post by Carol »
Sounds great. Thanks, Alex.
Carol
