One-time vs Subscription license
PhiloVance
Post by PhiloVance »
Time has come for me to renew again. Alex, I'm broke but I'll spend the money on UE and just stop eating for a while. I need to lose weight, anyway. :D
Is there any incentive to buy the Subscription License? I notice it's the same $35 as the One-time.
Re: One-time vs Subscription license
It is only for convenience, one time is even a bit cheaper since the expiration warning starts only after the license term has ended.
boston62
Post by boston62 »
alex wrote:It is only for convenience, one time is even a bit cheaper since the expiration warning starts only after the license term has ended.
Can you use the version that the license was paid for, and not upgrade to a newer version?
semel666
Post by semel666 »
yes you can use it.
only built-in search wont work if ur subscription expired.
Other than that u can use it indefinitely.
boston62
Post by boston62 »
semel666 wrote:yes you can use it.
where can we download older versions?
At the bottom of the UE download page, use the lost resend key form first to get your latest version number.
